LD1
Epic Contributor
Another question regarding some 3 phase equipment.
Along with the twistair compressor I got....I also acquired a old.monarch 16x54 lathe.
I have a junk (by comparison) clausing 1500 now in the shop....but it's actually a friends and at some point he is gonna want it back. So I got this monarch.
Dug down to the motor hoping it was a dual voltage motor.
No dice. High voltage only. So no way to currently run off phase converter.
Unlike many lathes that is specialized motors....this one is just a standard off the shelf 184t frame...1750 rpm....5hp. But 460-480v only.
So I basically think I have 3 options.
1. Buy a dual voltage 3ph motor so I can wire for low voltage and run off converter.
2. Buy a single phase 5hp and forget using my converter.
3. Leave lathe as is and buy a 6kva step-up transformer.
Spending about 5 min googling, it appears if I look hard enough, all 3 options can be sourced under $500. But I haven't don't a whole lot of looking.
So aside from cost...any advantages to one over the other?
Seems the simplest is just gonna be go single phase and forget the converter and forget the added wiring of a transformer or converter.
What do you guys think?
