3PH Snowblower at greater than 540 RPM PTO?
   / 3PH Snowblower at greater than 540 RPM PTO? #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
I recently purchased a Woods SB60 60" 3PH snow blower.
It worked great in these recent Mid-Atlantic snow storms. I was, however a little disappointed in how far it blows the snow. My 24in/10HP Simplicity walk-behind 2-stage snow blower throws it over twice as far. This was very powdery snow, the kind that snow blowers work very well in. I was running the engine on my B7610 at 2600 RPM, which gives a full 540 RPM at the PTO, and was not bogging the engine down at all.
I have a higher PTO speed available, which, of coarse would give a higher fan speed and throw further, but I didn't try it, because I'm not sure what speed you can safely use these at?
Anyone here running their 3PH blowers on a higher PTO speed?
High speed on the B7610 is 960 RPM, so, that would be 177% of the 540 RPM speed, so I'd probably have to run the engine at a lower speed, which, of course, would be lower HP, but might be find for lower accumulations of snow, or if I go slower.
Of coarse, this might be a good trick for those of you with more powerful engines.
Thanks,
Jay
   / 3PH Snowblower at greater than 540 RPM PTO? #2
Did you purchase new or used ?
   / 3PH Snowblower at greater than 540 RPM PTO? #3
Not giving you the green light...BUT, when we had the 60" Lucknow blower on the Bolens which had a 3spd PTO, we ran it on mid-range all the time...no issues....even when the snow was light & fluffy we've tried it out on high range PTO, LOL...
Blower is still alive and kicking behind a Kubota L2900 now...and he wishes the Kubota had a multi-speed PTO. My dad actually built a chain drive 33% speed increaser for it, but it kept snapping chains when the going got tough so its back to direct drive...
   / 3PH Snowblower at greater than 540 RPM PTO? #4
JAs67:
I wouldn't recommend running at the higher RPM speed. Blower was only designed to run at 540. My previous front mount blower had a reduction unit which then took it from the higher speed down to 540 or there abouts. Plus you would lose out on the power in the heavier snow since you have to run it at a lower RPM.
Having had the front mount blower before, even with the gear reducer, it threw the snow really far. I was a little worried with the new rear mounted blower that I just got that I would be losing out on this, but it does the same distance. Makes sense actually since they were both made by the same manufacturer. Not sure if you have the blower I looked at online at Woods, but I think the problem might be in the number of blades in the fan - only 3 on the 60" I looked at vs the 4 blades on the fan that my previous one had as well as this one. I have seen comments in other threads that seem to indicate more blades and a good size fan equals a good distance even at 540 RPM.
Used. It does have about a 1/2 gap between the blower blades and housing, so I might consider augmenting these this summer.
JAs67:
This one is three blades.
It's still WAY better than the back blade for these big snows.
   / 3PH Snowblower at greater than 540 RPM PTO? #8
That gap is what's hurting your performance. The fan should be able to pick up a nickel.
   / 3PH Snowblower at greater than 540 RPM PTO? #9
Bought it just south of Red Lion on Rt 24, didn't you?
Adams 8 Ton Weigh Hopper (A53473)
Adams 8 Ton Weigh...
1472 (A51247)
1472 (A51247)
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2008 FREIGHTLINER M2 106 (A53843)
2008 FREIGHTLINER...
AT 26in x 11-12in (A52377)
AT 26in x 11-12in...
