3PH scrubbing tires
/ 3PH scrubbing tires #1
duanet
Near Ithaca, NY
JD4100 HST
I've had a problem with minimal clearance in the inside of the R4 tires on my JD 4100 for the lift arms of the 3 point hitch. If the sway links (turnbuckles) aren't adjusted exactly perfect, I'll scrub the inside of the tire with the lift arms. I have seen this mentioned on a couple of the posts on TBN, and I don't want to turn the rims around and increase the width of the tractor.
The fix is real simple. Run, don't walk, to your nearest CT/Quality Farm Store before it closes (or someplace else) and buy a half dozen 7/8" flat washers. Before inserting the Lynch pins, slip two or three washers between the spee-ball and Lynch pin to take up the slack. This keeps the lift arms inward just enough to allow more room between the tires and lift arms. I "store" any extra/unused washers on the top link pin. It has worked well for me.
/ 3PH scrubbing tires #2
i had this same issue with the 3pt rough mower.
i switched the pins on the mower from outside to inside.
i also use the washer method on the other implements.
kobota mx5400 for sale
Steiner 48in Front Loader Tractor Bucket Attachment (A64553)
Steiner 48in Front...
2016 WIRTGEN W150CFI MILLING MACHINE (A65056)
2016 WIRTGEN...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
PORTA POTTY (A67714)
2011 FORD F-550 SUPER DUTY (A67714)
2011 FORD F-550...
