3PH restrictor plate
/ 3PH restrictor plate #1
sxs191
What is the restrictor plate for? I saw it on my B3200 being delivered on Friday.
/ 3PH restrictor plate #2
Just where did you see a restrictor plate?? Maybe a picture would help.
This pic is from Tom's B3300 but mine has the same thing.
/ 3PH restrictor plate #4
My guess is it should of came off at the dealer. I see no reason for it other then to lock lever in place for shipping. Maybe check with dealer or manual and see if can find it in there.
/ 3PH restrictor plate #5
Do you have a backhoe? Someone mentioned in another thread it is to lock out the 3 point lift if you have a backhoe installed.
Hercules 25 Gal Sprayer (A64127)
Hercules 25 Gal...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
Case IH 5100 12ft. Soybean Special (A65640)
Case IH 5100 12ft...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2023 New Holland Boomer 45 Tractor (A65579)
2023 New Holland...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
