3PH plot thickens
   / 3PH plot thickens #11
Youare, my Iseki has a fine-mesh screen for the trans/hydraulic fluid and because of water I've had the fluid changed since then. There was some debri caught by this including metal from clashing gears. My other tractor is a FORD 1910 and it has a $27 paper like filter that probably catches finer debri-- once it gets to it. I bet tho it's the "macro" debri that can hang up a SVC valve. On the Ford I had to open up the differential from the top to free-up a dfferential lock and there was alot metal debri in the bottom of the case (gear tractor) which communicates with the transmissions. Its easy to imagine a shard of metal getting mobilized before a filter stops it.
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
1999 CPS TRAILER COMPANY BELLY DUMP TRAILER (A58214)
1999 CPS TRAILER...
POLY TOTE W/ METAL CAGE & PALLET (A52708)
POLY TOTE W/ METAL...
(2) CASE IRON POT BELLIE STOVES (A58374)
(2) CASE IRON POT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
