3PH Log Splitter
/ 3PH Log Splitter #12
Just use all 1/2 QD's.
/ 3PH Log Splitter #13
Brad_Blazer
If the splitter just has the typical in and an out, you can run the tractor out to the splitter in and the power beyond to the splitter out.
I am not sure I understand your statement.
The log splitter will obtain fluid from the PB adapter from the loader valve, and the OUT will go to tank or a return hose. .
/ 3PH Log Splitter #14
JJ, Here is the original post:
I own a Kubota BX25. Which hydraulic lines do I use to hook up my splitter?
There's three lines: Outlet, Return and Power beyond
I am assuming what he describes as "outlet" is coming from the loader power beyond and his "Power Beyond" is supplying the 3-point. I recommended hooking up the splitter in the power beyond loop between the loader and 3-point, taking some precautions because the splitter valve is not really made for power beyond.
He could connect the splitter between the loader and the tank return but the 3-point will not function. This will be inconvenient since the splitter is on the 3-point.
/ 3PH Log Splitter #15
I agree, and to keep the valve from possible damage, once the log splitter is setup, he could disconnect the PB QD and plug in the log splitter and run the log splitter OUT to tank..
Switching back to 3pt would only take a few minutes.
A two way hyd valve would also work to switched between log splitter and 3pt. .
207272 (A52708)
207272 (A52708)
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2023 Big Tex 16GN (A60462)
2023 Big Tex 16GN...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
