3ph lift arms
   / 3ph lift arms #1
JohnCt
sw. ct. & s.vermint
Kioti /DK40
I have a DK40 TLB and just happen to try to raise the lift arms while the backhoe is attached.and nothing happened. I called the dealer to ask if the backhoe being attached would effect the the lift arm functunion on th 3ph? ( I know I can't use 3ph while backhoe is on, just wanted to see if it would operate.) Well the dealer had no idea if this is normal or not .He did suggest to disconnect the hyd.lines and than try the lift arm function. He also said that he was installing a backhoe on a Dk35 at the end of this week and would try the 3ph function . I won't be up Vermont till this weekend so I can't disconnect the backhoe lines till then to find out if this is why the 3ph doesn't work. Any input would be appreciated. Thanks, John
   / 3ph lift arms #2
They may or may not lift. It depends on the way, the hydraulics are plumbed. Check the manual that came with your backhoe, it should show a schematic.
   / 3ph lift arms #3
Is your backhoe plumbed in though your rear remotes? If so this would explain why it doesn't work. If you have your rear remotes in detent the 3 pt will not function.
   / 3ph lift arms
Thanks for your replys. I got to check things out this weekend.Backhoe has to be disconnected and hyd hose plugged into 3ph. All is well. Thanks again, John /forums/images/graemlins/smile.gif
New/Unused CFG Industrial MX12RX Mini Excavator (A51573)
New/Unused CFG...
2002 International 9200i Truck (A53472)
2002 International...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
2002 Freightliner FL70 Elgin Street Sweeper Truck (A51692)
2002 Freightliner...
2012 Audi Q5 AWD SUV (A51694)
2012 Audi Q5 AWD...
