3-Point Hitch 3PH Lever Not Working
   / 3PH Lever Not Working #1
Old Blevins
south of Everett, WA
Kubota B7500
My 3PH lever has stopped working, either for bringing the 3PH up or for letting it down. It feels like it's not engaged.
I checked the linkage and where it fits over the shaft going into the casing, there's a pin insert that looks to be most of the way out toward the front of the tractor. It wouldn't push back in. I tried inserting a slim nail in the other end of the hole to engage what I assume is a shaft in there, and it went in quite a way but made no difference. The lever moves far more easily than it usually does and seems disengaged. Any ideas on what to try before I haul it into the dealer?
   / 3PH Lever Not Working #2
It would help knowing what model tractor you have.
   / 3PH Lever Not Working #4
You're probably going to need to take it in. There is a peice under the 3-pt cover that breaks that is likely the problem.
Brian
   / 3PH Lever Not Working #5
Sometimes wiggling the front bucket will help will free up the 3PH.
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
Cat TH407C Telehandler (A51039)
Cat TH407C...
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
