Planters 3ph flex 71 planters any good?
   / 3ph flex 71 planters any good?
That's a beauty of a planter. I've seen aome now for less than those on ebay, but they aren't as nice as yours!
   / 3ph flex 71 planters any good? #12
Thank ya! As I mentioned, we made up a pair of these planters when I dismantled the 4-row. A cousin of mine helped with the hitch and painting part, as I was mid stream in the middle of moving at the time. Plan was to keep one and he'd buy the other. Never worked out that way. He got in "money troubles" and couldn't pay. My son ended up with #2. If I was to change anything, the 3-point top link "mast" would have been about 3 or 4" taller. Sort of an odd geometry to the hitch as it is.
I planted 1/3rd of my sweet corn last saturday. It took longer to hitch and unhitch the planter than it did to plant 1/4-acre. No one will ever convince me that there's another type of planter that's more "user friendly" as well as easy for a "first timer" to understand how they work. Minimal moving parts.
   / 3ph flex 71 planters any good? #13
What is the big limiter on how many row planter you get? Horsepower? Since something like corn is best planted in blocks versus long single rows it would seem better to plant as many rows per pass as you can. A single row planter would seem to create a lot of compaction as you would have to make a lot of passes.
Charles
   / 3ph flex 71 planters any good? #14
Charles
Let's see... There's cost, hydraulic capacity, need, field big enough, ect.
Deere, among others sells planter units that can be mounted on any toolbar. There are quite a few toolbars available wide enough to handle as many as 48 rows. (biggest I've seen. In a picture. May be bigger) A planter that big needs multiple hydraulic hook-ups, electrical power supplied by the tractor, and a tractor with enough guts to drag something that big. Not to mention, a field big enough to turn it around.
Most likely, with the needs of a typical TBN'er, 2, 4, maybe even 6 row would be all they'd ever need. (maybe more) There are a few guys here still involved in production agriculture, but most are planting food plots or big gardens.
With a row unit like a #71 Deere, and a smaller tractor, you need to concern yourself with lift capacity and over-all weight carrying stability. Almost any tractor would still handle 4 rows, but by the time you work up to 6 rows, you have a wider and heavier planter that'll whip some tractors. Horsepower generally isn't too much of an issue with 2 or 4 row planters. By 8 to 12 rows,you'll likely be using a drawn planter as opposed to mounted. Hydraulic demends usually exceed what a lower hp tractor would have to offer before running out of horsepower. Also, as the planter gets wider, it gets heavier. It takes traction AND power to move weight. Even with 4wd, bigger planters usually take a heavier tractor to pull in all conditions.
   / 3ph flex 71 planters any good? #15
Thanks! I have a b7100 gear and I was scratching my head at using a one row planter for corn, my garden would be packed down like a driveway by the time I was done! So it sounds like I can definitely use a 2 row and maybe a 4 row.
Now I just need to find one :)
Charles
   / 3ph flex 71 planters any good? #16
Charles
If you need more than a 2 row planter and have a big enough tractor 40+ hp then you should look for an older 7000 series pull type planter in 4 or 6 row. You will need hydraulic outlets and probably 10 to 12 HP per row to pull it.
   / 3ph flex 71 planters any good? #17
Charles
I just looked up the b7100, I am not up on the Kubota numbers. You will need to take into consideration row spacing. Most hobby farmers use one row planters with their CUT's because they can not use 2 rows without either planting in 20" rows or planting right in the track left by the tractor. Not good with the compaction. I am using a 2 row with my JD 790 and I can only get 26" row spacing and stay inside the rear tire tracks. A lot of guys like the one row because they can just use the tire tracks left by the last pass as a guide to drive on. In my case I will drive right next to my existing tire track and that will give 26" to 28" spacing on my guess row.
   / 3ph flex 71 planters any good? #18
i have also been looking at planters for the past couple of seasons. liked the flex 71 for all the reasons mentioned but i found a john deere max-emerge 2 row unit that i ended up buying. it was a refurb unit. i bought it over the 71 for 2 reasons. 1 that it was plateless. i have planted my corn and sunflowers allready with no changes needed. 2 no till coulters make it a true no till planter. it had all new bearings new drive shaft and new openers. it was 1000.00 without coulters and 1300.00 with coulters. picked up at dealer in dyersburg tn
   / 3ph flex 71 planters any good? #19
IANAF (I Am Not A Farmer) ;) but most people around here seem to plant corn at 15" spacing. I did some measuring one day and it seemed that I could work with 15" row spacing. This area is primarily flood irrigation so what I am looking at is some type toolbar with the type of cultivator sweeps that hill/furrow. Then of course I need something to plant the seed in the hills with which is why I am curious about the planters. At 15" spacing a single row planter seems less than ideal. Of course I also have no idea what I am talking about ;) I am hoping to pick up an old cultivator that looks like it will do what I want at an auction. I was one once but my wife called about 20 mins before they started on the implements and needed me to bring her lunch, it had gage wheels and everything. Once I get that attachment I can mess around and see what is possible.
Thanks for the info!
Charles
   / 3ph flex 71 planters any good? #20
In the old days here in the midwest corn was planted in 36", 38" or 40" inch rows. Then about 1980, everyone started switching to 30" rows. That is still the most common row spacing but there are many farmers around here going to 20" rows I would think that 15" rows would make it hard to keep a corn head on track.
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
2012 SOUTHERN 130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
2006 Hyundai Sonata Sedan (A55853)
2006 Hyundai...
TANK MANIFOLD (A55745)
