3PH falls when engine off
   / 3PH falls when engine off #1
pabney
Henning Tennessee
Mahindra 1526S
I have a Shibaura sd2203. If I lift the 3ph and then shut the tractor off the 3ph immediately falls. Just as if I lowered it with the lever. Is this normal or should the 3ph stay up?
Paul
   / 3PH falls when engine off #2
It should stay up if there's an implement on it, but slowly sinking without one is pretty common. Just falling, don't sound right to me. /forums/images/graemlins/tongue.gif
   / 3PH falls when engine off #3
Have you checked the adjustments for raising and lowering the three point?
Egon
The lift arms fall both with and without and implement.
Egon,
What adjustments are you referring to? There is a knob below the seat that adjust how quickly the arms lower, but changing this makes no difference.
Paul
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
UNUSED CFG QUICK ATTACH HYD POST DRIVER (A51248)
UNUSED CFG QUICK...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
