3PH Failure
/ 3PH Failure #1
BroncoKrawler
Cub Cadet 7260
Hello there! I just purchased a Cub Cadet 7260 with a FEL. I’m new to tractors and this is the first I’ve owned. I’ve run into an issue with the 3PH. It will only move up and down about 1 inch. The FEL works just fine under significant weight in all positions. Some other observations of the 3PH are below.
- I can freely move the hitch by hand up to the most upright position with very little effort.
- I cannot move it down further by hand or by standing on it with the pressure knob in the full open, closed or in between positions. It’s sort of in a “medium position”
- When it’s at its max “up” point (1” from “medium position”), it will hold with weight.
- The adjustment lever requires to push all the way down or up to move. The limiter is at the far ends.
Since the tractor has a FEL and from reading the owner’s manual, I understood that the transmission and hydraulics shared the same fill point as there was only one capacity mentioned and the manual stated to change transmission and hydraulic fluid together. I might need to mention I have a gear drive. Is this correct about the fluid? Is it all on the same “circuit”?
With the very little that I know, I am looking to do the following in attempt to fix the 3PH and wanted some feedback if I’m headed in the right direction as there doesn’t seem to be a multitude of info on these tractors.
1) Change the transmission/hydraulic oil and filter. Curious of how I would determine a blockage?
2) Change the 3PH piston seal and O-rings. Should I go ahead and do this during the fluid change?
3) Give up and have a shop fix it!
Appreciate the advice in advance. New to the forums and tractor ownership, so apologies if I didn’t provide enough info.
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2013 PROFAB 200BBL CRUDE TANKER (A65643)
2013 PROFAB 200BBL...
1988 Fruehauf 42' Tanker Trailer (A64127)
1988 Fruehauf 42'...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
Inflatable Canoe (A64127)
Inflatable Canoe...
2019 GMC Terrain, AWD (A62679)
2019 GMC Terrain...
