3ph cutter lift height
   / 3ph cutter lift height #1
chieff
I just received my 6' cutter for my L4330 and I hooked it up to my tractor to move it into the shed today. I have used an older ford tractor many times and my 4330 doesn't seem to lift the cutter as high as it should. I have adjusted the top link to level out the cutter and the full lift height is about 2' off the ground. The ford lift height is much more than this. I have checked the three adjustment levels for the top link as well. Is this just the normal lift height of the grand L series?
Thanks
Chieff
   / 3ph cutter lift height #2
Wow - I wish mine would lift 2 feet! This is usually a function of the placement of the lift pins on the cutter frame, although I think that CUT's don't lift as high as utility tractors, generally speaking.
The King Kutter is notorious for placing the lift pins too high on the frame (see attached - cutter is at maximum lift). Several members have lowered the pins to get more height, but unless you need it for traversing gullies or some other reason, it seems that 2 feet should be more than enough for transport.
   / 3ph cutter lift height #3
</font><font color="blue" class="small">( King Kutter is notorious for placing the lift pins too high on the frame (see attached - cutter is at maximum lift). Several members have lowered the pins to get more height )</font>
I was one of them.
Couldn't lift the cutter high enough to suit me, so I lower the lift pins 5". Problem solved !
   / 3ph cutter lift height #4
Chieff,
Do you mean 2" (inches) as I'm thinking 2' (feet) is tonnes of height!!!
If you mean inches, then you are in the same boat as many of us. There are a lot of threads about lowering the lift pins on the cutter to improve the height.
Kevin
Thanks for all the posts. I measured the height and I am right at 18" off the ground. I have just been used to an old ford and it will lift a different hog 3.5' off the ground. I have not checked my new cutter on the older tractor so It may just be the pin height on the cutter. My cutter is a hawkline and so far I really like it. I am new to the GrandL series and just didn't know if it was just my tractor with the low lift height.
Thanks again.
Chief
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
2017 KENWORTH T370 SERVICE TRUCK (A51406)
2017 KENWORTH T370...
