3PH Control
/ 3PH Control #1
Mpabe
Moreland, Ga
YM 2000
I got my 2800 today and immediately bush hogged about four acres of grass that ranged 4-6 ft in height with a 5 ft bush hog. Other than hearing the turbo kick in occasionally, the tractor didn't seem to notice; I was very pleased! I was running in 1H gear. I did think about going to 2H but it seemed too fast when you really can't see much ahead. The only complaint I had was with the 3PH control lever. Moving it from lowest position to half way up didn't seem to have any effect. But at the halfway mark it began moving the 3PH upwards, fast. In short, moving the lever did nothing except for about a half inch section at the midway point. In that quarter inch the 3PH went from the lowest position to the highest. Is there a way to adjust the lever?
/ 3PH Control #2
Yup, there's a knob just below the front of the seat, that adjusts hyd. flow to 3pt.
2437 (A65640)
2437 (A65640)
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2015 Kubota ZD1211RL 74in Zero Turn Mower (A64553)
2015 Kubota...
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Hypac C330B Tandem Smooth Drum Roller (A64553)
Hypac C330B Tandem...
