3ph bucket w/ hydraulic center link
   / 3ph bucket w/ hydraulic center link #11
Another picture.
Yeah that's exactly what I was thinking of. Thanks alot for the great picture!! Have a great day!
   / 3ph bucket w/ hydraulic center link #13
hey Bud, does that rigid bucket with no tipping frame, have enough dump angle with the hydro top link only ??
It is a very simple bucket, i think it could even be cheaper to make a bucket like this, and buy a hydro top link with it, than the Dutch type of buckets with additional tipping frame.
I will keep this in mind when replacing our 3p lift bucket... /forums/images/graemlins/laugh.gif
...Tye, i think i should have read your question better... /forums/images/graemlins/smirk.gif
   / 3ph bucket w/ hydraulic center link #14
Nice. And unlike a FEL bucket, you can tilt it to the side.
John
   / 3ph bucket w/ hydraulic center link #15
That looks just like the ones a guy who used to be here made a few years ago. Dang if I can not remember his name though...
Looks pretty cool!
Roughly, how much did it cost? My Bushhog QT loader was $3100 installed.
   / 3ph bucket w/ hydraulic center link #16
That bucket is not rigid, I have a hydraulic top link on it, and it will dump past 45 degrees when the 3PH is in the up position.
Bud
   / 3ph bucket w/ hydraulic center link #17
This is the valve I used. It's one of the three I had, with joysiicks, from the 352 loader. So I put it under the seat and used it for the rear hydraulics.
Bud
   / 3ph bucket w/ hydraulic center link #18
I have made a tipping bucket on my 16HP tractor with 3PH and it works great. With the 3PH all the way up it will dump the load at almost a vertical angle. The bucket is designed to have the pivot point about 12" from the rear of the bucket which makes it dump when you release the latch. I have moved a lot of dirt and haled fire wood for years. Now I plan on making a loader for my tractor this year.
   / 3ph bucket w/ hydraulic center link #19
I plan on making a rear end loader..
We have a front loader on my brother's Deutz D50. i think it weighs about 2000 kg, and has no front wheel drive.
When i lift a wrapped silage bale that is fairly saturated, (it might weigh over 900 kg) the rear end comes off the ground and the 5.50-19 front wheels allmost tear apart under the load.
When i drive through our grassland i get big wheel tracks, and last week, when i drove off the street, into a mud bath it stopped within two feet, and the rear wheels came of the ground, kind of submarine experience when it dived into the mud.
I think when i want to collect wrapped bales in wet conditions, the 16.9-30 duals on the rear of our 5245 will just float on 0.8 bar pressure, without soil or sod damage.
When i want to put a bale in the field where our herd of 15 horses are during winter, it will walk easily through the mud even with a 2wd without duals, because the load is put on the driven axle.
I wont need a powersteering either... That Deutz with FEL is a nightmare for your arms and shoulders, it lacks powersteering..
2014 Jeep Patriot SUV (A55758)
2014 Jeep Patriot...
2013 Jeep Patriot Sport 4WD SUV (A55758)
2013 Jeep Patriot...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
Electric Mobility Scooter (A55853)
Electric Mobility...
Sawmill YC-26G W/ Gas Motor (A47477)
Sawmill YC-26G W/...
2018 Ford F-150 Ext Cab 4X4 Pickup Truck (A55788)
2018 Ford F-150...
