3940 gst won't crank
/ 3940 gst won't crank #1
toyocruiser
Central Alabama
My 3940 gst displays "shuttle neutral" whenever I try to crank it. It is just over 2 years old with 256 hours on it. I have looked for a neutral safety switch but apparently it is located inside the transmission. Any help would be appreciated.
/ 3940 gst won't crank #2
Disconnect the harness connector & check switch resistance with ohm meter?
You'll probably need a wiring diagram to figure out which terminals on the connector to check.
One of the issues is I do not know where the shuttle indicator switch is. I have removed the covers but it is not visible there. I am afraid it is inside the transmission.
/ 3940 gst won't crank #4
I know absolutely nothing about your tractor, but when I have an issue, I always check the fuses first. Easiest thing to check when t comes to electronics.
If you know it's the sensor and just tying to locate it, sorry for my .02
Well I found it. Mice have been busy. I was fortunate they haven't done more damage.
/ 3940 gst won't crank #6
That's good the damage wasn't worse. I often worry about the same thing happening to my tractor but I'm not sure there is anything to do to prevent it. I don't think I can get my barn tight enough to keep mice out.
/ 3940 gst won't crank #7
Well, cheap but frustrating.... I'm glad you found it.
/ 3940 gst won't crank #8
Glad you found the cause.
Maybe time for a cat - or a terrier?
/ 3940 gst won't crank #10
My KTAC insurance is up for renewal on my L4400 with 250 hours and I want to know if you wiring issue with rodent damage was covered or would be if available by the Kubota insurance???
2005 TerraGator 8104 (A63688)
2005 TerraGator...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
1983 John Deere 2940 Tractor (A62613)
1983 John Deere...
Peterbilt 377 Semi-Truck (A63689)
Peterbilt 377...
Farmall Cub Tractor (A62613)
Farmall Cub...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
