3930 transmission overheating
   / 3930 transmission overheating #1
professor
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
Sorry, I goofed and placed this on the Kioti forum!
Yesterday, I was cutting thick blackberry brambles and thick weeds and I noticed the transmission/hydraulics overheating. Oil levels were fine. It has a remote valve controlled by one lever. It appears the lever has three positions up/float/down. I know if the lever is left up the oil could deadhead and cause heat build up. The lever was in the down position and I am wondering if this could cause deadheading too. By the way the rotary cutter is a 3-point model and there was nothing hooked to the remote. Do any of you have other suggestions as to waht would make it overheat and what damage could the overheating cause? Thanks for any help you can give. The tractor has 970 hours on it.
   / 3930 transmission overheating #2
Do you have 2 hyd hoses for remotes?
   / 3930 transmission overheating #3
Red, the easiest way to answer your question is to tell you to put the remote lever in the neutral position and then move it downward to that position slowly. If you hear the engine load up and then the hydraulics go to bypass, it means you are forcing the hydraulics to run in bypass all the time with the lever down or up and that generates plenty of heat. I'm surprised that your 3PH lift worked because normally remotes are in the open-center system before the 3PH. However, because you were in bypass, the 3PH probably had some backpressure available to the lift. Keep that remote in neutral or float and you will make your hydraulics work much better I am sure.
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A51692)
2006 Ford F-550...
2008 Ford F-250 Crew Cab Pickup Truck (A51692)
2008 Ford F-250...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
