3930 crankshaft seal
   / 3930 crankshaft seal #1
Busy_Dad
Weiser, ID
BCS 722 and 1953 JD MODEL 40
I currently have the tractor split replacing the clutch. There seemed to be a lot of oil in the housing, and on the back of the fly wheel. I'm thinking it may be the crankshaft seal. How difficult is it to relieve the seal? I just can't seem to find any info on replacing the crankshaft seal. Is it just behind the cover with the 8 screws and 2 from the oil pan?
Thanks
   / 3930 crankshaft seal #2
It is very easy to replace the seal on this engine. Remove the seal housing that is bolted to the block. Look at the crankshaft for a deep groove the seal may have made. If it is very deep you have 2 options. One option is to reposition the new seal so that it is not riding in the same place. Second option is to install a Speedi Sleeve 99472. Search for best price option.
Rear main seal is part # E5NN6701BA. Use old seal to install new seal.
Also, check rear freeze plugs. Yours look to be stainless so you are probably okay, but if not, now is the time to replace them.
   / 3930 crankshaft seal #3
Pull Behind Wood Splitter (A57453)
Pull Behind Wood...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
