3910 owner
/ 3910 owner #2
I had one for 14 years. good powerful machine for its size. If 2wd a loader is hard on the front end, if it has an auxilarry engine driven hydraulic pump it has very strong hydraulics. Keep oil in it and don't use ether to start it in the cold unless you absolutely have to.
/ 3910 owner #3
Welcome to forum!
I've got a 1986 2-wheel drive 3910. Good strong runner that will pull a 3-bottom plow if you don't go too-too deep. I've been working most of the summer on dressing her up. Just too hot to work all day so it gets put off. I originally planned to build a cab for it but that's on the back burner. I need to get it back in service and do a little work on the other tractors.
/ 3910 owner
strong machine mine a 2 wheeler too a 1985 diesel just putting thing back together several issues added up over the years.
/ 3910 owner #6
good day looking forward to chatting
Please enter your general location in your profile.
It can help others to help you, if necessary.
set of 4 tractor trailer tires Roadforce (A61307)
set of 4 tractor...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2009 FREIGHTLINER CASCADIA (A60736)
2009 FREIGHTLINER...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
