3840 Glowplugs won't turn off.
   / 3840 Glowplugs won't turn off. #1
binthere
I have a Montana 3840 with 65 hours on it no problems until today when I put it in the barn I noticed the glowplug indicator was on. I had been using the tractor about 30 minutes. I turned the key off and on a couple of times even restarted and let the motor run a few minutes. Turned the key off and still the glowplug indicator stayed on. I finaly found a jumper on the alternator side of the motor that felt hot so I pulled it off and the light went off. I would appreciate anyones Ideas.
   / 3840 Glowplugs won't turn off. #2
I don't know anything about your specific tractor but I would look for a relay that puts the power to the glow plugs. It is actuated most likely by a wire from the key switch. It could be sticking shut, which would cause the glow plugs to always be powered.
   / 3840 Glowplugs won't turn off. #3
I just had a similar problem with my key switch. It would want to shut the tractor off while I was running it. Then it would not start becuase something in the switch was wrong. I would call your dealer and see if you can get a new switch and go from there.
   / 3840 Glowplugs won't turn off. #4
I had this problem on a ford pu. The relay shorted out. I would check the relay first.
   / 3840 Glowplugs won't turn off. #5
Agree with most, the relay is the first place i'd check. the keyed switch provides power constant to the relay, or there may be a timer system also. either way, something is not telling the glowplugs to power down. relay first-easiest and cheapest
   / 3840 Glowplugs won't turn off. #6
I have a 4940c with about 220 hours. It is having the same problem. I have been unplugging the relay under the dash and it will go off.
   / 3840 Glowplugs won't turn off. #7
As stated , it would be the contact points in the relay welded together . But now that the glow plugs have been on for so long they are more than likely burnt out .
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
2015 FREIGHTLINER CASCADIA DAYCAB (A52472)
2015 FREIGHTLINER...
2011 INTERNATIONAL PROSTAR PREMIUM (A52472)
2011 INTERNATIONAL...
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
