3830 GST Error 20
/ 3830 GST Error 20 #1
alanjb
North GA
Kubota 3830
I have a 3830 GST with 65 hours. While using a blade a lost drive power. The display read Error 20, and the GST light flashes. I am now stuck in the woods. Anybody got any ideas? /forums/images/graemlins/confused.gif
/ 3830 GST Error 20 #2
Do you want to know what the error means, or do you want to know how to get out of the woods???
Or Both? /forums/images/graemlins/confused.gif
Sorry your stuck
/ 3830 GST Error 20
Both, I can get it to a position I can get it on my trailer, I am just hoping my winch can pull it on the trailer if I need to take it to the shop.
/ 3830 GST Error 20 #4
As per my shop manuel: ERROR20, communication error between ECU and electronic instrument panel(GST model) probably cause: fuse blown out: communication line between ECU and electronic Instrument panel is broken or short circuited: No signal from ECU for longer than 5 seconds( error cleared if signal sent and received later): ECU defective: Sounds like you got a bad fuse or a loose connection.
/ 3830 GST Error 20 #5
Check your fuse, check for a loose wire. Not being there could a stick have come up in underneath the tractor and pulled the wire from it's connector?
/ 3830 GST Error 20
Thanks for the info. I will check after Lunch (Turkey-Day)
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
2006 LeeBoy L8510R Low Deck Asphalt Crawler Paver (A66734)
2006 LeeBoy L8510R...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
Kubota L3901HST
Kubota L3901HST
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
2018 Ford F-250 Ext. Cab Pickup Truck (A66736)
2018 Ford F-250...
