3830 GST Error 20
/ 3830 GST Error 20 #1
alanjb
North GA
Kubota 3830
I have a 3830 GST with 65 hours. While using a blade a lost drive power. The display read Error 20, and the GST light flashes. I am now stuck in the woods. Anybody got any ideas? /forums/images/graemlins/confused.gif
/ 3830 GST Error 20 #2
Do you want to know what the error means, or do you want to know how to get out of the woods???
Or Both? /forums/images/graemlins/confused.gif
Sorry your stuck
/ 3830 GST Error 20
Both, I can get it to a position I can get it on my trailer, I am just hoping my winch can pull it on the trailer if I need to take it to the shop.
/ 3830 GST Error 20 #4
As per my shop manuel: ERROR20, communication error between ECU and electronic instrument panel(GST model) probably cause: fuse blown out: communication line between ECU and electronic Instrument panel is broken or short circuited: No signal from ECU for longer than 5 seconds( error cleared if signal sent and received later): ECU defective: Sounds like you got a bad fuse or a loose connection.
/ 3830 GST Error 20 #5
Check your fuse, check for a loose wire. Not being there could a stick have come up in underneath the tractor and pulled the wire from it's connector?
/ 3830 GST Error 20
Thanks for the info. I will check after Lunch (Turkey-Day)
2005 Sterling 9500 Truck (A66736)
2005 Sterling 9500...
2025 20in. Rotary Brush Cutter Mini Excavator Attachment (A66734)
2025 20in. Rotary...
Bush Hog 3815 (A64911)
MAGNUM TRANSFER PUMP (A67714)
MAGNUM TRANSFER...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
