3820i Fuel Pump replacement - Aftermarket?
   / 3820i Fuel Pump replacement - Aftermarket? #1
psyched123
Waco, Tx
Branson 3820i
My 11 year old 3820i needs a new fuel pump and I just found that the part from Branson is over $130. Are there any aftermarket fuel pumps that a parts house would carry that would work?
Also, which position on the fuel filter valve is open? The markings are in Korean.
Thanks!!
   / 3820i Fuel Pump replacement - Aftermarket? #2
Usually the lever pointing down is on and pointing to the side is off.
Is the pump an electric lift pump like on current Bransons or something else?
The lever swings from straight up to straight down with Korean characters on each extreme. I think it is an electric lift pump. The pump is connected to the firewall as seen in the attached picture.
   / 3820i Fuel Pump replacement - Aftermarket? #4
I replaced my 3510 lift pump (on firewall) with a Mr Gasket Diesel pump from parts store 4-5 years ago.
It was about $60.
   / 3820i Fuel Pump replacement - Aftermarket? #5
It depends on what the requirements are for your injection pump.. According to your pictures, your inj. pump requires 3-5 psi.. to the pump inlet.
Check out the Airtex E8251
The BIGGEST PROBLEM w/ people changing out their electric lift pumps is, they get one that has the WRONG pressure.. More is NOT better..
Good luck.
   / 3820i Fuel Pump replacement - Aftermarket? #6
Good luck.
So best to match factory spec?
It makes sense although "more is better" also seems logical on some level.
:thumbsup:
   / 3820i Fuel Pump replacement - Aftermarket? #8
That's a nice pump right there.. & 4-7psi is whats needed. Think I'll save that one to "my favorites".. Thanks, Stimw.
I just bought a new Mr. Gasket 12D diesel transfer pump off Ebay for $28 shipped. That saved over $100! Thanks so much for the recommendation!!
Thanks for looking in your shop manual and finding the info on the correct lever position.
What a great resource this forum is!
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53473)
2023 NEW HOLLAND...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53473)
Michelin CARGOXBIB...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
