Price Check 3820 pricing
/ 3820 pricing #1
carpenter383
Platinum Member
Indiana
Kioti DK40SE
I am a new member on here and don't yet have a tractor. This site has been very helpful. I've been researching tractors in the 35-40 hp range. I have basically decided branson is the 1 for me. Here is my question......I have 2 dealers within an hour away. Dealer A is the closest and wants almost 20,000 for a new 3820 with a fel. Dealer B is about an hr. And wants 17,900 for the same tractor. I told dealer A about the price difference, thinking he would beat dealer B's price, he told me that 17,900 is less than dealer cost and there is no way he could even match the price! Is he pulling my leg?
/ 3820 pricing #2
Which dealer do you feel most comfortable with?
Which one will be better able to help you should there be problems in the future?
The answers to these questions should help you decide if the $2,100 price difference is significant.
/ 3820 pricing
Well the higher priced dealer is closer, but smaller. Maybe I should ask this question....Do all dealers get the same prices from the branson distributor? Also If I did have a warranty issue would I have to go back to the dealer that I purchased the tractor from or will any Branson dealer cover warranty work?
/ 3820 pricing #4
I went to a different dealer for less than half that amount of money, both 50 miles away, different directions.
If you have a trailer, an hour drive isn't that bad and that's only if you have a problem. If you can do your own service you probably won't need either dealer.
I have the 3510 and I love it! When you get done with your nessary chores you will look for other things to do! I let a friend of mine drive it and he could not believe how great it felt, he said it drives like a car.
/ 3820 pricing
Thanks for the reply, I've heard many good things about branson tractors. I'm planning on getting 1 in the next couple months. I've been kinda holding out to see what the economy is gonna do
/ 3820 pricing #6
Carpenter, where abouts in IN. are you located?
I have 2 Branson dealers closer in IL than the one in Indiana
where I bought my 4720 from.
Cost was my big issue also, I wanted all the tractor I could get
for the least amount of money!
And like yourself I have a shop and work on Jeeps so
doing my own maintenance is not an issue.
I really dont remember how much I saved but I know it was well over $2000!
/ 3820 pricing
I'm about an 1 1/2 hrs south of Indy....Do you know if there are any differences in the 3820, 4220 and the 4720 besides the engines? I'd like to get ag tires, but it looks like r4's stick out more, which seems more stable
/ 3820 pricing #8
I would ask how long the prices are good for. With spring around the corner the buying season will start soon and hesitating might cost more.
When I want to buy something I will start thinking, TWO MONTHS!! They might all be sold by then!! ;)
I LOVE the R-4's very stable and the tractor looks so much meaner!
/ 3820 pricing #9
Any difference, not that I know of....
Actually I have had both 3820 and now my 4720.
The 3820 that I had 1st had an issue, hard starts lots of unburned fuel.
Come to find out it had the wrong glow plug starter......
anyway I ended up with a 4720.
The only difference I know of is HP,
that being said it's hard to tell the difference in HP.
They both push and pull like pit bulls!
The 4720 has been flawless, no problems at all with the tractor.
I did have a hydo leak on my Back-Hoe but the tractor has been
all and more than I would expect!
All most forgot, I did notice both of my tie-rods needed to be
tighten up a little bit.
Gene
/ 3820 pricing #10
Yep I'm with Stimw, R-4's are the way to go!
/ 3820 pricing
I've read on here before where people had some problems with tie rod ends breaking on the 20 series. I assume by now branson has corrected this issue? Also if the 4720 uses the same clutch as the 3820, it may be more likely to slip with the added hp under a hard load? How is the loader lift capacity? Does it have plenty of power? I was reading elsewhere on here about shimming the pressure relief valve on an L3400 kubota to get more lifting power
/ 3820 pricing #12
Hmm, the tractor is most likely heavier than any thing in it's class,
I have never slipped the clutch.
For the most part I keep some sort of weight on 3pt
usally my box scraper to keep the rear wheels from lifting
when picking up heavy loads with the loader.
I have picked up CJ7 no axles or motor and sat it on my car trailer ;)
/ 3820 pricing
Haha a cj7? That's the kind of real world experience I like to hear, I can put that into perspective!
/ 3820 pricing #14
I have a Yanmar 2002 (25 HP) and a Ford 9N. I also have a 2006 Branson 3820 with FEL. I purchased the Branson with 60 hr on it from Dave's Tractor's in Edinburg IN. Dave offered the best price on a new or used tractor. I looked at several Mfgs of tractors and decided on the Branson based on price, owner feed back and test driving. My Branson has been worry free and I am not easy on machinery. Dave is an honest guy and talking to some of his customers - they are satisfied with his service. I like the R4's as I use my Branson for mowing, hauling, grading, and pulling. If I was just working the fields, I would opt for the AG tires. The only problem I have had with the R4's is they don't give as good traction as the AG tires but they also don't tear up the turf as badly when my lawn is wet.
/ 3820 pricing
Ok thanks for the input kolob5!
(INOP) LAYMOR SM300 RIDE-ON SWEEPER (A65054)
(INOP) LAYMOR...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
AUTOMATIC TRANSMISSION / TRANSFER CASE (A68842)
AUTOMATIC...
2013 Audi Q5 AWD SUV (A66738)
2013 Audi Q5 AWD...
213088 (A64276)
213088 (A64276)
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A66734)
2025 Kivel Quick...
