3725H price check
   / 3725H price check #1
Fireman1317
Greenfield
Branson 4225H
Went and test drove a 3725H today. Not sure if its a 2017 or 2018, other than it has the old seat without arm rests, but they said they could swap seats if I wanted. Was quoted $32,500. Tractor, FEL, Rear Remotes to be added, 3rd function to be added, 6ft Land plane or Land leveler, 6ft rotary cutter, free delivery. Dealer is an hour away and been selling Branson since 2002. Any thoughts?
Went in thinking I wanted the 4225H, but not sure I need the extra 5HP. Think there was something like $2,000 price difference between 3725H and 4225H. Of course 4225H would have to be ordered in as well.
   / 3725H price check #2
That would "seem" a bit high to me. I see just the tractor with fel offered in a few places for 25-26 thou. Considering the "extras" being offered are probably in the 4000 dollar area it would put the tractor and fel around 28thou. Of course different areas of the country have different pricing also. I'd check around your area a bit and see, then if you find it at a lower price see if the dealer will price match (or close). As to the difference between the two models I believe they are the same tractor but the 4225 just has a bit more HP. Up to you if you feel you need it or not. I have a 4020R and it is the exact same tractor as the 3520R but mine has a turbo for the added HP but I have read the "consensus" on the 4225 just has different injectors and possibly a different "tune"....I am just repeating what I've read from others on that though. Either one, both are very nice units..
   / 3725H price check
There is another Branson dealer in the state that is 2 hours away. I will check with them as well. I know that I can go to Texas or Kansas and probably get a better price at a volume dealer. I guess it comes down to if its worth the extra money to go with a closer dealer.:confused3:
   / 3725H price check #5
I'm not sure by the way you worded that, "to be added"... ? Does that mean that your price includes all that, rear remotes, 3rd function, and both attachments? Or is that price before adding the rest of that?
   / 3725H price check
That price includes all of that being installed plus the two attachments.
   / 3725H price check #9
It's not an amazing price, but I'd say it's not bad. If the other dealer can do better it's worth a try.
Did your dealer break down your price per each item, or only give you the total price for the package?
   / 3725H price check #10
The price difference between cheapest possible rotary and a good medium duty one can easily be $1k. I don't know about land planes but I expect since they're not as common as rotaries and box blades that the price on that might be more. So that makes it hard to compare prices.
Are they including things like hooks on the bucket and loaded tires for that price?
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (INOPERABLE) (A52472)
2019 PETERBILT 567...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
2023 JACTO ARBUS-1000 LOT NUMBER 69 (A53084)
2023 JACTO...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
