3720 Where does your block heater mount?
   / 3720 Where does your block heater mount? #1
jim gerken
rochester, mn
John deer 3720
I want to add a block heater to my jd 3720 engine. The dealer says it is part number AR87167. Dealer can't say over the phone for sure where it goes on the engine. I found a threaded plug on the left side, below and aft of the alternator, with a 3/8" square recess. Is this where the heater threads in? The problem is, there is a large low pressure hydraulic formed hose blocking straight access to this location.
The heater may come with instructions, so they may steer me straight. But I thought I'd ask before driving twenty miles to buy it, possibly having to return it. I don't want the heater if it's something I can't install myself.
Thanks!
   / 3720 Where does your block heater mount? #2
I’ve installed block heaters on a 2305 and a 2530 using the screw out plug you described. Can you loosen up the connections to the hydraulic hose to aid the install? Good Luck. Frank
Yes, I can remove the low pressure hose, if this is the correct location for the heater. The boss I'm looking at is an inch and a sixteenth diameter, approx.
I may have to go buy the heater just to find out more info.
   / 3720 Where does your block heater mount? #4
The heater is about 2" behind and 4" down from the alternator. Hope this helps. It is the thing with the red cap.
Reviewing this the picture is very small and I don't know why. You can blow it up a little if unsure
Thanks for the pics! That's the spot I assumed it might mount. Guess I'll go buy one tomorrow. It's pretty cold here now in Minnesota. Merry Christmas.
I checked the JD site. It is more sales literature than ever. Less available technical content than the last time I used it. Unless I'm missing something, or they are hiding it well.
   / 3720 Where does your block heater mount? #8
Jim,
He is referring to the parts site, the same basic one the guys at the parts counter use. It’s free to register.
JDParts: Unsigned Landing Page
   / 3720 Where does your block heater mount? #9
Oh, weren’t you registered at TBN before with a bunch of posts?
UNUSED FUTURE SKID STEER QUICK ATTACH SWEEPER (A51244)
UNUSED FUTURE SKID...
CATERPILLAR D6R XL CRAWLER DOZER (A51242)
CATERPILLAR D6R XL...
HYD 4N1 PIN ON COMBO BUCKET (A51243)
HYD 4N1 PIN ON...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
PALLET OF RTV SILICONE (A51244)
PALLET OF RTV...
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
