3720/fuel in oil/won't restart
   / 3720/fuel in oil/won't restart #1
lsxlowtech
2210 john deere
My dad bought a 3720 tractor with a cab. It has 1200hrs. on it and is well taken care of. He was driving it around some and plowing with it, then it shut down and would not start. He checked the oil and found fuel in it and it was way over full. He checked it all out when he got it so this is something new. Any help would be great. Is it a leaking nozzel? or worse. thanks JC
   / 3720/fuel in oil/won't restart #2
Hiya
How did you determine there was fuel in the oil? Just the smell or with an analisys?
If the 3720 is anything like my 3320, it has an electric primary fuel pump so the posibility of a mechanical primary pump leaking and pumping into the crankcase is eliminated. However it does have a mechanical secondary pump, as that can fail and pump fuel into the engine it could be the cause of both the no start condition and the fueled oil.
Secondary fuel pumps are not cheap to replace so I would suggest contacting a reliable dealer or independent Diesel mechanic to diagnose the issue
   / 3720/fuel in oil/won't restart #3
You sure it's not hydraulic fluid in the oil ?
//greg//
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
New/Unused Agrotk Horizontal Band Sawmill (A51573)
New/Unused Agrotk...
