3720 e-Hydro losing power
/ 3720 e-Hydro losing power #1
rideralberta
Saskatoon, SK
3720 JD
In the past month, my 3720 compact John Deere has been losing power. I can't lift as much weight, get as much speed, or accelerate as quickly. I changed my hydraulic fluid and both the inline and large filter, but same thing.
Any ideas?
/ 3720 e-Hydro losing power #2
Blocked fuel filter perhaps?
/ 3720 e-Hydro losing power #3
I am making the assumption that you have ehydro? Also that the fluid level is up on the "XXX", and colder temps/thicker fluid is not sluggish to start the day and fails to improve?
If the engine seems to be bogging causing the trouble, I'd look at air or fuel delivery issues, but it sounds like your hydraulic flow is restricted/gpm is low.
When you say you changed the inline filter, you disassembled the inline screen/strainer on the port side of the machine and brought the screen back to bright? If you have power beyond installed, there is similar screen in the back that may be blocked. How many hours are on the machine? Has it been prone to cavitation? Any fluid leaks?
207280 (A52708)
207280 (A52708)
2018 Ram 1500 Reefer Meal Delivery Truck (A61568)
2018 Ram 1500...
UNUSED WOLVERINE PT-16-01C UNIVERAL ATTACHMENT (A62131)
UNUSED WOLVERINE...
ROLL OF 6' CHAINLINK FENCE (A62131)
ROLL OF 6'...
(4) Trail Finder S2 215/75R/17 Tires and Rims (A64047)
(4) Trail Finder...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
