3720 e-Hydro losing power
/ 3720 e-Hydro losing power #1
rideralberta
Saskatoon, SK
3720 JD
In the past month, my 3720 compact John Deere has been losing power. I can't lift as much weight, get as much speed, or accelerate as quickly. I changed my hydraulic fluid and both the inline and large filter, but same thing.
Any ideas?
/ 3720 e-Hydro losing power #2
Blocked fuel filter perhaps?
/ 3720 e-Hydro losing power #3
I am making the assumption that you have ehydro? Also that the fluid level is up on the "XXX", and colder temps/thicker fluid is not sluggish to start the day and fails to improve?
If the engine seems to be bogging causing the trouble, I'd look at air or fuel delivery issues, but it sounds like your hydraulic flow is restricted/gpm is low.
When you say you changed the inline filter, you disassembled the inline screen/strainer on the port side of the machine and brought the screen back to bright? If you have power beyond installed, there is similar screen in the back that may be blocked. How many hours are on the machine? Has it been prone to cavitation? Any fluid leaks?
2022 John Deere DR16 Planter (A63111)
2022 John Deere...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
