Aug 26, 2017 / 365 plow off of a 650 tractor #1 S Snojetter New member Joined Jul 13, 2017 Messages 16 Location Brandon, MN Tractor Allis Chalmers, John Deere, M-M Any chance a 365 plow that came off a 650 will fit onto an 855 without modification?
Aug 26, 2017 / 365 plow off of a 650 tractor #2 B beenthere Super Star Member Joined Aug 16, 2001 Messages 18,591 Location Southern Wisconsin, USA Tractor JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold) Possible.. as that blade is for both. The trick may be the attachment is a bit different frame design. So may not be a direct fit. Go to JD Parts John Deere - Parts Catalog and see the two frames listed for the 650 and the 855
Aug 27, 2017 / 365 plow off of a 650 tractor Thread Starter #3 OP S Snojetter New member Joined Jul 13, 2017 Messages 16 Location Brandon, MN Tractor Allis Chalmers, John Deere, M-M I'm not sure if I'm interpreting the parts diagrams correctly. The tractor frames are obviously different, but it looks like the sub-frame for the plow itself is the same. But I can't tell if there's an adapter specific to each model tractor...
