3638 century
/ 3638 century #1
dostep
salem mo
2 ford 8n's acentury 3638 and a jd 60
I can get a 3638 century with industrial tires and a humpolec fl 030a loader with bucket and forks. I can find nothing on this model at all. It has 75 hours and compares a lot if not identical to a branson 3820. anyone know anything about this.
/ 3638 century #2
the tractor is the same - the loader isn't.
my 2535 had the same specs as the Branson 3510, but the humpolec c50hl loader was significantly stronger than the loaders Branson's ship with - in fact, i suspect it would have caused me problems eventually, because the loader was capable of lifting and carrying more than the front axle was rated for.
if it's in good shape and the price is right, you should have a good machine there.
/ 3638 century
Thanks Eric I thought they were the same. I can find no info on the tractor at all other than h.p. I would like to know the year and if the loader is o.k. The tractor looks new except for the usuall 75 hours of use. Also there is no manual. doug
/ 3638 century #4
email the Branson folks and see if they have a manual that matches - that's how I got mine.
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
SDlanch SSL60 (A64912)
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
2015 KOMATSU PC308USLC-3E0 EXCAVATOR (A65056)
2015 KOMATSU...
2005 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A66736)
2005 Mack CH613...
2011 PREMIER PUMP AND POWER 3IN 3HC-DM16 TOWABLE PUMP (A67714)
2011 PREMIER PUMP...
