Loader 3601 Loader cylinder repair
/ 3601 Loader cylinder repair #1
Ric44090
Wellington,Ohio
I have a 3038 with a 3601 loader. The seal on one loader arm cylinder(not bucket cylinders) has failed and the other side is not far behind. Contacted LS dealer. Out of warranty (1 year on attachments) and no parts available through LS. There solution ..buy a new cylinder.
Has anyone else run into this ? What was your remedy?
/ 3601 Loader cylinder repair #2
There are places that rebuild cylinders, though I don't know which ones are around you.
I'm not sure if your loader was built by AmerEquip or not, but if you find out who actually manufactured the loader, you may be able to contact them directly and buy a replacement part or cylinder.
There are also aftermarket cylinder options available.
Thanks for the reply. Going to try the local New Holland dealer first. The should be familar with these machines
/ 3601 Loader cylinder repair #4
Unfortunately that won't do any good ... NH uses their own loader, parts won't be interchangeable.
/ 3601 Loader cylinder repair #5
LS does make the Boomer 20-50 HP series for NH but they do not use the same loaders as LS. NH orders their tractors from LS pretty much bare bones with no loader, then the purchaser is responsible for buying the options such as telescopic lower links, rear work light, rear remotes, rubber floor mats etc. Pretty sure the NH cylinders will be different from yours because NH uses a different vendor for their loaders.
/ 3601 Loader cylinder repair #6
My local NH dealer was able to find parts and repair the lift cylinders for my DU AL loader on my L355 Kubota. Around $250 per however!! Will be looking at new for other tractors needs in the future.
Dennis
/ 3601 Loader cylinder repair #7
If it is just seals they are just simple items to repair. If you are mechanically inclined and know of a hydraulics shop close to you get a kit and fix them yourself heck I did a bunch of them on my hoe it's not hard if you have the tools. The hardest part is taking the cylinder apart and that isn't to bad either. If you are not comfortable doing it find a small hydraulics shop it shouldn't be too expensive, IF you don't go to a dealer they are expensive. Well that's my:2cents:!
I have the tools and ability to do it my self. Been a long time since I had to do a seal. I know this is asking for a "guess" but as long as a seal is dimensionally correct, is a seal a seal or do I need a seal produced for that particular cylinder?
/ 3601 Loader cylinder repair #9
Just take it apart and have it with you when you order the new ones. Mine were older seals and were different that the new O-ring type.
/ 3601 Loader cylinder repair #11
So how did your rebuild go?
I was able to find the cylinder rebuild kit from LS dealer at around $80, says all four cylinders use the same kit....so I am taking mine to local hydraulic shop to see if they are a common and can score them slightly cheaper.
Had local hydraulic shop do it for me $105 .Four day turn around
/ 3601 Loader cylinder repair #13
HOLY S!!!!! I got the parts drop shipped from LS to house since dealer is 2 hours away....$93!
Packet is marked
SL21CRK
Spirit 2 x 1 1/4
Tried to cross reference, no luck....open packet and found the cup number and it matched ok, for 9 pieces $93, I am headed to a hydraulic shop next week, 2" x 1 1/4" should be a fairly standard item and I should be able to cross these new ones. I will post update with parts numbers
/ 3601 Loader cylinder repair #14
Sourced the parts locally this week, you can take your cylinder and have them order parts or ask for a 1.25" rod x 2" bore seal kit...each kit was $20
Rebuild time was about 45 minutes, I did it on the tractor ...
/ 3601 Loader cylinder repair #15
/ 3601 Loader cylinder repair #16
I have an LS G3038 with a LL3601 loader and figured i'd share what I found since information for these seems to be hard to come by.
I searched the internet for days. Falling short on my research, I went to my local LS dealer and was told they do not sell a seal kit and they could send them off to be rebuilt or sell me new cylinders for $900 each.
All four of my cylinders are leaking very badly and I did not want to pay large fees for such an easy job of replacing seals. I found the following part numbers for seal kits online, but only found one reseller advertising them, which was on Amazon for $80/each.
Seal Kit Part No. LS3600-SL21CRK or 39001150.
Instead of spending $320 and hoping it was the correct parts, I disassembled one cylinder then took the seal head and piston to two local Hydraulic shops and each one said I would have to leave them and be charged a fee to identify the parts. I then decided I would measure and identify the parts myself as it would end up being a lot cheaper and I want to ensure I have the part numbers for the next time.
After careful measuring and visual comparison to seal options at herculesus. com, I was able to identify all the parts needed for a rebuild. I did find that some other websites sell different brands of seals under different part numbers, using the dimensions can help find a usable part if the retailer you want to use doesn't have some of these parts. Total for all four cylinders was about $130 from Herculesus. This includes larger packages of the o-rings as they do not sell them individually. Also, you will need a U-Seal installation tool($13.12) as you cannot install these stiff u-seals without it.
Piston Seal
Qty: 1
Part Number: PS2700-32
ID=1.691, OD=2, H=.119
Piston Guide Wear Rings
Qty: 2
Part Number: 609-200-019
ID=1-13/16, OD=2, H=3/16
Piston O-Ring
Qty: 1
Part Number: 568-018
ID=3/4, OD=7/8, c/s=1/16
Rod U-Seal
Qty: 1
Part Number: U18-1.25-31B
ID=1-1/4, OD=1-5/8, D=5/16
Rod Wiper
Qty: 1
Part Number: AN-13B
ID=1-1/4, OD=1-1/2, D=.104
End Cap O-Ring
Qty: 1
Part Number: 568-224
ID=1-3/4, OD=2, c/s=1/8
End Cap Back-up Ring
Qty: 1
Part Number: 573-224
ID=1-3/4, OD=2, D=.05
Rod U-Seal Install Tool
Qty: 1
Part Number: SEAL TWISTOR M
Size M(30mm-50mm)
Prior to rebuilding my cylinders, I also looked at options to replace them. I did find an inexpensive replacement dump cylinder but didn't find anything for the lift cylinders.
Magister Hydraulics WTG 2x16
They can be found for less than $140 each.
/ 3601 Loader cylinder repair #17
Awesome info! Thank you for posting your research! :thumbsup:
Parts are hard enough to find for these machines. Any help, resources, strategies for research, etc is extremely helpful.
I have had to research seals for all different types of cylinders. Most of the time its easy enough as most of the cylinders are standard sizes (that I've had to deal with). But every once in a while, there is a curve ball thrown in the mix. Like wheel bearings, they are easy when you know the part numbers and sizes, but when you dont... :mur:
/ 3601 Loader cylinder repair #18
Piston Seal
Qty: 1
Qty: 2
Piston O-Ring
Qty: 1
Rod U-Seal
Qty: 1
Rod Wiper
Qty: 1
Part Number: AN-13B
End Cap O-Ring
Qty: 1
Qty: 1
Qty: 1
Size M(30mm-50mm)
Are these the same specs for the LL3106 loader?
/ 3601 Loader cylinder repair #19
My total for one cylinder kit using the above numbers came out to over $90? How did you get four sets for $130?
