Tires 360 W/loader- Right tire catches the hoses in full turn
   / 360 W/loader- Right tire catches the hoses in full turn #1
Slacker
Durham, NC
Farmtrac 360 TLB
Just a heads up to the FT DTC owners, noticed yesterday that on full right turn (near wheel lock) the rear of the right front tire catches/rubs the FEL hydraulic hoses. My tires are R4's. R1's may be slightly taller and more prone. If it catches just right, it'll rip the hoses off the connectors, either from the joystick or loader side. This will probably result in the front loader falling to the ground. Be careful on hard right turns, its only a matter of time for my tractor.
   / 360 W/loader- Right tire catches the hoses in full turn #2
Just wondering, are you going to correct the problem, or just wait till something happens?
I'm still on the fence. The machine is under warranty so it would be covered.
I don't see many places to re-route the hoses. Should I call the dealer and let him deceide what action to take? I bought a new tractor so I wouldn't have to deal with mechanical issues, normal service excluded.
   / 360 W/loader- Right tire catches the hoses in full turn #4
Why would you not want to call the dealer?
Give him the opportunity to make you completely satisfied.
   / 360 W/loader- Right tire catches the hoses in full turn #5
I looked at my hoses today and mine look like they have about 1-2 inches of clearance from tire at full turn. Do yours run right against the FEL brace? Can you pull the hoses either up or down to lessen the "droop" in the hoses? I'm assuming they are slightly slack.
Yes, they have a little slack in them and are zip tied very tight to the FEL brace. The hoses are quite rigid, but I may be able to pull some slack to one end or the other.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
1985 Ford Ltl9000 Tender Truck (A55301)
1985 Ford Ltl9000...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
