Tires 36" tires on jd 855
   / 36" tires on jd 855 #1
kimodc
Bronze Member
Does anyone have 36" turf tires on the back of their JD 855? If so, how to they work and how do they look? My 33" tires are getting bald and I have a chance at a set of 36"-ers that were said to be used on an 855. I am just worried they will turn my tractor into a 'dog.' And they need to look good too!
Thanks,
Kim
   / 36" tires on jd 855 #2
The 855 has 4WD correct? You need to be very careful of the front-to-rear ratio's so you don't damage the drivetrain.
   / 36" tires on jd 855 #3
The 36 inch tires were a factory option on 755 and 855. My 755 cannot use them because they are not compatible (clearance issue) with the 60 inch MMM. The 855 longer wheelbase does not have that problem. I do not believe there would be a clearance issue with the 855 even with the 72 inch MMM. The 955 has the 36 inch tires as standard equipment, but it also uses larger front tires. Like KennyD I also have wondered about tire diameter differences causing problems even though the factory offered the larger rear size for the 755/855.
I did not realize 36"s were optional equipment. My tractor is a 2wd so I am not worried about matching up with the fronts. Any pictures of 36's on a 855?
   / 36" tires on jd 855 #5
   / 36" tires on jd 855 #6
I made an improper assumption. I should know never to assume. JD Parts says the 36 inch tires, while available for the 855, are not compatible with the 72 inch MMM. So kimodc I don't know what deck (if any) you may have but this could be a problem.
Since I have brand new 36's on order, we will just have to wait and see. I do have a 72" mmm but I never use it, I mainly just use the front end loader and pull trailers around. I was able to find new softrac 33" but at $360 per tire I just couldn't do it. Instead I was able to find new factory blem 36" for one third the cost. If I remember correctly, I don't recall the rear tires coming all that close to the mower deck before, so I am still hoping the 36's will clear it.
2006 X-L SPECIALIZED 40TON RGN (A50854)
2006 X-L...
2018 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2018 Ford F-450...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
1990 KENWORTH T800 FUEL AND LUBE TRUCK(INOPERABLE) (A50854)
1990 KENWORTH T800...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
2018 FORD F-150 XL (A50854)
2018 FORD F-150 XL...
