35Hp @ drawbar pull 2 bottom plow in 2nd gear?
   / 35Hp @ drawbar pull 2 bottom plow in 2nd gear? #1
Waverlywoods
Oliver 550
should I get a 1 or 2 bottom plow? My Oliver 550 Has tranny issues. 2 and 4 are good. 3 is out and 1 clicks alot, so i will have to pull in 2nd gear, this year anyhow.
   / 35Hp @ drawbar pull 2 bottom plow in 2nd gear? #2
2 bottom. You'll turn alot more ground on each pass, and your 550 might be able to pull a 2 bottom in 4th gear.
Ha ha, well that's definelty good to hear. I don't know anything yet, but I'm learnin
   / 35Hp @ drawbar pull 2 bottom plow in 2nd gear? #4
You should be able to find a 2-14 or 2-16 plow fairly easily. Spring trip is an important feature if you are doing new or rocky ground.
I would encorage you to hold out for a 2-16 plow if you had a solid 3rd gear, but without 3rd gear a 2-14 would give you better odds of plowing in 4th.
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
Athey 7-12D Force Feed Loader (A52384)
Athey 7-12D Force...
HAMM 3307 SMOOTH DRUM ROLLER (A51246)
HAMM 3307 SMOOTH...
2008 Lincoln Electric Ranger 250GXT Trailer-Mounted Welder (A51691)
2008 Lincoln...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
