35Hp @ drawbar pull 2 bottom plow in 2nd gear?
   / 35Hp @ drawbar pull 2 bottom plow in 2nd gear? #1
Waverlywoods
Oliver 550
should I get a 1 or 2 bottom plow? My Oliver 550 Has tranny issues. 2 and 4 are good. 3 is out and 1 clicks alot, so i will have to pull in 2nd gear, this year anyhow.
   / 35Hp @ drawbar pull 2 bottom plow in 2nd gear? #2
2 bottom. You'll turn alot more ground on each pass, and your 550 might be able to pull a 2 bottom in 4th gear.
Ha ha, well that's definelty good to hear. I don't know anything yet, but I'm learnin
   / 35Hp @ drawbar pull 2 bottom plow in 2nd gear? #4
You should be able to find a 2-14 or 2-16 plow fairly easily. Spring trip is an important feature if you are doing new or rocky ground.
I would encorage you to hold out for a 2-16 plow if you had a solid 3rd gear, but without 3rd gear a 2-14 would give you better odds of plowing in 4th.
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53472)
2019 New Holland...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
PALLET OF ARMSTRONG CEILING TILES (A51248)
PALLET OF...
