35ft toolbar walking
   / 35ft toolbar walking #1
ret13
salix ia
john deere 9430
I am pulling a 35 ft manure injection bar with a 9430 about 5.5 mph and cannot get it to stop walking back and forth. I need to be at this speed to apply the accurate rate of manure. I can't reduce the gallons any more than I have so slowing down is not an option. we're using coulters and going about 6 to 8 inches deep. Any ideas?
   / 35ft toolbar walking #2
Welcome to TBN.
Sadly, you are probably on the wrong site for this problem. But, with that said, your best chance of getting an answer would be in the John Deere AG section. Good luck.
   / 35ft toolbar walking #3
are you using chains from the end of the bar to the front of the tractor? Other than that I got nothing.
   / 35ft toolbar walking #4
And that is one HUGE tractor.
   / 35ft toolbar walking #5
and I realized that this is an articulated tractor and you CANNOT run chains to the front.
:eek:
   / 35ft toolbar walking #6
:eek:
I knew that was an oversight on your part so didn't comment. Additionally he's probably got a pull-type applicator which again negates the ability to use chains.
I hope he gets some valuable advice. Probably not gonna happen on this thread..... Maybe if posted in the JD AG section. Hopefully he'll find an answer somewhere. :)
   / 35ft toolbar walking #7
Is this hitch trailered or axle mounted ? If trailered, change (drop) the hitch point to lower the tongue. You should check the trailed axle alignment(s) to make sure they are toed in. Otherwise it will walk (wander in a limit cycle).
A picture would help.
1993 Trail Boss Lowboy Trailer (A52384)
1993 Trail Boss...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Peterbilt 377 Semi-Truck (A53473)
Peterbilt 377...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51691)
2016 Peterbilt 567...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
