3550 FEL Joystick replacement Options
   / 3550 FEL Joystick replacement Options
I appreciate the help. Now I at least know what I should be looking for. Dealer wants 460.00 for a replacement. Thanks again.
   / 3550 FEL Joystick replacement Options #12
Hmmm that’s obviously high! The aftermarket brand is less even with new cables! Ask TBN on the hydraulics forum and or call the surplus center. You can also look for a post a few weeks ago from a Mahindra dealer who will ship parts.
Thanks, I'll check em both out.
   / 3550 FEL Joystick replacement Options #14
I think the new one you get from dealership will come with new cables. The one I got come with everything ready to hook up then you adjust it so joystick is centered. Mine was for a 4035 but probably the same thing since its the 35 series.
Thanks, I'm trying to find something else to use or somewhere else to get it. 460.00 for a cable joystick sounds steep to me.
   / 3550 FEL Joystick replacement Options #16
The loaders I have worked on the JS cables are just attached with set screws . I would think that there would only be a few manufactures of the joystick . I doubt the Tractor manufactures build there own so they should be kinda of generic .
Thanks everyone for the help. I still would like to find a different brand of joystick although I was able to fix this one. I was able to back the screw out of the knuckle where it attached to the plastic housing and add a larger washer where it had pulled thru the housing. So far everything is working great. I did discover what caused the mishap. There is a round ring on the grip that has a rod that goes thru the center of the joystick. That can lower enough to pass thru a hole in the center of the housing and locks the joystick. Not sure of the purpose of this unless it is a lock for the joystick. Thanks again.
   / 3550 FEL Joystick replacement Options #18
Mine has a lock also, the ring is at the top of the boot and when I center the joystick I push down on ring and it locks. I think its a safety thing and if you didn’t have front end loader on it might keep you from putting pressure on the lines forcing it in bypass. I read something about it in the book but like most things I can’t remember. Glad you got it fixed and hope you have no more trouble with it. Good luck
   / 3550 FEL Joystick replacement Options #19
what you have there is a Cofle brand joystick they are found on several tractors. i am working on one right now where the cables are dragging real hard internally. which is a big problem with these joysticks. we have 3 tractors with it on there and have had to replace all of them some two times, they are not very reliable. i havent found anywhere where you can just buy parts for it, and its dealer only in most cases.
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2019 DODGE RAM 3500 (A52472)
2019 DODGE RAM...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
