3550 FEL Joystick replacement Options
   / 3550 FEL Joystick replacement Options #1
Swalls
Morganfield,Ky
Mahindra 3550
Hi all,
I've purchased a Mahindra 3550 which I have used and enjoyed for the past couple years. Yesterday I broke the joystick to the FEL. I was told this was not under warranty. If I have to replace this on my coin I would rather not go back with something that is secured to plastic. I found a two spool 12 gpm by Prince that is very reasonable.
(2 Spool 12 GPM Joystick Loader Control Valve
ITEM NUMBER: BB9-12239).
I've never swapped one of these out before. So is this the correct valve? Is there a better one for about the same or more money that is better quality and smoother. I'd sure like to here some voices of experience. Thanks
   / 3550 FEL Joystick replacement Options #2
Can you take a photo of the valve that broke? I don’t know that model and it would be good to verify if the valve has a pressure reducer in it.
Yes, I'll try and post one later this evening. Thanks
   / 3550 FEL Joystick replacement Options #4
Check with bailey hydraulics . I bought one from them a few months ago for my old JD that was a 2 stick and he recommended a 21gpm 2 spool joystick and my tractors listed 14.5 gpm total flow .
Can you take a photo of the valve that broke? I don稚 know that model and it would be good to verify if the valve has a pressure reducer in it.
Here's a few pictures of the joystick.
   / 3550 FEL Joystick replacement Options #6
So all you need is the joystick that is compatible with your cables
   / 3550 FEL Joystick replacement Options #7
So your valve is fine (glad we asked for photos!). That is the joystick. The two lines coming off the bottom are actually cables that go to a valve that is probably down by the transmission and floor.
If you need a new joystick I would ask about a factory one. If you don’t want a factory one you will need to find out if joysticks are interchangeable across brands- the ratios may be different.
How do I figure out what cables I have?
Im glad you asked for the photos too. LOL. So the joystick actually just uses cables?
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
Tires 25x10-12 (A50322)
Tires 25x10-12...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2002 International 4400 SBA 4x2 Flatbed Truck (A50323)
2002 International...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
