3535 Neutral Safety Switch Install Question
   / 3535 Neutral Safety Switch Install Question #1
tomnytractors
North Central Texas
Gear tractor with loader. Neutral safety switch is worn and doesn't always make the connection to start. What's the best access to remove and install a new one? Looks like removing fuel tank may be easiest but wondered if anyone has suggestions.
   / 3535 Neutral Safety Switch Install Question #2
JUST BEEN PLAYING AROUND WITH THE NO START PROBLEM ON MY MAHINDRA 3535. WHEN IT'S WARM IT SEEMS TO START MORE OFTEN. WENT UNDERNEAT AND DROVE A THIN BLADE SCREW DRIVER TWX THE SWITCH AND THE GEAR SHIFTER AND IT STARTED RIGHT UP. I HAD TO PLAY WITH THE SHIFTER TO GET IT JUST RIGHT BUT IT STARTED. THEN JUST THIS WEEK WITH THE COLD TEMPS AND NOT RUNNING IT ALL WEEK IT WOULD NOT START. WENT UNDER TRACTOR AGAIN ( NOW I'm SOUNDING LIKE FOREST GUMP), DROVE THE SCEW DRIVER TWX THE SWITCH AND THE SHIFTER. IT STARTED BUT I HAD TO PLAY WITH THE SHIFTER. THAT WASN'T TO MY SATISFACTION SO, BACK UNDER I WENT AGAIN (FOREST). THIS TIME I DROVE THE SCREW DRIVER TWX THE BALL AND SWITCH, SPRAYED IT WITH BP BLASTER, JAMED SCREWDRIVER IN AND OUT AND SPRAYED SOMEMORE. LOW AND BEHOLD, TURNED THE KEY TO START AND IT STARTED. SHUT IT OFF, PUT IT IN FORWARD THEN BACK TO NUETRAL AND IT STARTED. I DIDN'T HAVE TO SEARCH FOR A SWEET SPOT ANYMORE. WHERE EVER I PUT IT IN THE NUETRAL POSITION IT STARTED. HERE'S HOPING THAT THIS KEEPS WORKING AND THIS POST HELPS SOMEONE ELSE. THIS IS THE FIRST TIME I EVER GOT ON ANY SIGHT. I'm 74 YEARS OLD , STRUGGLING WITH COMPUTERS. JUST DOING THE TECH THING BY TRIAL AND ERROR.
   / 3535 Neutral Safety Switch Install Question #3
Just WENT THROUGH 1 WEEK WITH OUT ANY PROBLEMS, UNTIL TODAY. APPARANTLY , THE BP BLASTER WASN'T THE CURE. NOW, I'M COCIDERING PUTTING IN A STARTER BUTTON. I DON'T SEE MYSELF CRAWLING UNDERNEAT AND TRYING TO R AND R THE OLD NUETRAL SAFTEY SWITCH. IF I DO I WOULD BYPASS THE NUETRAL SAFETY AND I'M NOT SURE IF THATS WHAT SHOULD BE DONE. EVERY TRACTOR I EVER OWNED HAD A STARTER BUTTON WITH NO PROBLEMS, BUT IN TODAYS WORLD YOU HAVE TO BE PRO SAFETY OR YOU MIGHT GET SUED. ANY THOUGHTS ON A STARTER BUTTIN?
1996 Dodge Ram 3500 (A50515)
1996 Dodge Ram...
66" Bucket (A47384)
66" Bucket (A47384)
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
1.5 Rolls of Red Brand Barb Wire (A50515)
1.5 Rolls of Red...
