Oil & Fuel 3535 first service
   / 3535 first service #11
3535 only came in shuttle. You also should only need to swap the hydro filter an not the oil unless its over a year old. The air filter can be cleaned but if it to far gone go ahead and replace it. Id also blow out the radiator while your at it. Its a pretty simple service youll be fine
   / 3535 first service #12
Oh usually the 4wd models have two drain plugs on the engine because the shaft splits the oil pan. Make sure you drain both
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
53" HAY FORKS, 3PT (A52708)
53" HAY FORKS, 3PT...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
2013 JOHN DEERE 650K LGP CRAWLER DOZER (A52709)
2013 JOHN DEERE...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
(2) METAL WELDING STANDS (A58374)
(2) METAL WELDING...
