3525 Steering problems
/ 3525 Steering problems #1
natebub
Coldspring Texas
Mahindra 3525
My 3525 doesnt steer worth a flip most of the time. I can turn it either direction and stop steering and the wheels want to go back to center. Could it be the steering cylinder bypassing or is it in the Hydraulic steering block that goes to from the steering wheel to the cylinder. I have no visible leaks nor and i losing fluid. I had changed the fluid and filter to see if that would clear it up but nothing changed.
/ 3525 Steering problems #2
sounds like the cylinder is bypassing.... but can be either or. Is it still under the 2yr warranty?
/ 3525 Steering problems #3
my bad thought you said 4025 ha no warranty on the 35
/ 3525 Steering problems #4
Take the lines off one side of the cylinder... turn the steering wheel to the opposite side of that line.. and when you get to the point were it usually goes back to the center it will either shoot fluid out of the cylinder or the line... that should tell you which one is bypassing .... makes sense in my head at least
/ 3525 Steering problems #5
do you see any visible leaks on either or? To me it would make more sense that its the HSU causing the problems
