3525 Steering Cylinder
   / 3525 Steering Cylinder #1
Shemp
I got an 07 3525 that I need to replace the steering cylinder on. A Mahindra cylinder goes for $400 and up from what I致e found so far. Does anyone know of an aftermarket cylinder that I could use instead? Thanks.
   / 3525 Steering Cylinder #2
The steering cylinders shouldn’t be too special. You could probably rebuild it or have it rebuilt by a good hydraulic shop. Even a custom cylinder should be less than $400.
   / 3525 Steering Cylinder #3
Take your cylinder t a regular hydraulic shop. Get a price on a rebuild or replacement. You may even be able to rebuild it yourself.
My shaft is pretty bent up so looking for options for another shaft
   / 3525 Steering Cylinder #5
If the part is lunched, you will need to pull it and take it to a hydraulic shop. Or pull it and call places online. They will need to see it and or specific measurements to make a repair or replacement. A generic double piston cylinder is probably about $200. So you will need to determine if all the time spent chasing this down is worth it. If it has good steering stops one that is close in length with the same diameter may work fine.
378567 (A51573)
378567 (A51573)
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
HLA LOT NUMBER 168 (A53084)
HLA LOT NUMBER 168...
