3525 owner has 3pt plow question
   / 3525 owner has 3pt plow question #1
boog0909
fingerlakes area in upstate ny
John deere 5055 & mahindra 2015
looking to buy a plow for plowing a couple acres before i hit it with the disc.My question is should i looking at a single or can i use a 2bottom the soil is pretty heavy some clay . I believe the tractor weight is around 4400lbs and engine hp is 37. Any responces would greatly appreciated
   / 3525 owner has 3pt plow question #2
It should handle 2 16" bottoms quite handily. Where are you located, my daughter lives on Seneca Lake. Also when buying a used plow, make sure the bottoms are true and not sprung. There are a lot of bad ones out there.
   / 3525 owner has 3pt plow question #3
Your tractor will handle a two bottom plow no problem.
I'd recommend two 16s. Make sure you get a plow that
has good coulters and is adjusted properly on your hitch.
2012 RAM 5500 (A52472)
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
JLG 4045R 40ft Electric Scissor Lift (A50322)
JLG 4045R 40ft...
Loader Arm (A51691)
Loader Arm (A51691)
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
1 T Truck Dump Bed (A50515)
1 T Truck Dump Bed...
