3525 fuel tank
   / 3525 fuel tank #1
jtmathman
Lindale,TX
Mahindra 3525
The fuel tank on my 3525 is full of what looks like some kind of greenish paint chips. They keep clogging my fuel lines and filters. Has anybody had this problem? If so, how did you fix it?
   / 3525 fuel tank #2
I would take the tank off, flush it out good, clean the inside good with solvent, get some fuel tank sealer like they use on motorcycle tanks, prep the inside of the tank with acid as the sealer directions will say to, and then coat the inside of the tank with the sealer. I think that would be a long term solution.
   / 3525 fuel tank
Thanks, I'll give it a try.
UNUSED FUTURE FT1000J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
2015 John Deere 8245R MFWD Tractor (A53342)
2015 John Deere...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2024 KMC 7406 LOT IDENTIFIER 11 (A53084)
2024 KMC 7406 LOT...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
