3525 3pt hitch loose bolts
   / 3525 3pt hitch loose bolts #1
deerefan
louisiana
1952 8N, 2005 JD 5103
A buddy of mine has a new 3525 and is having a small problem. On the right side of the tractor, where the adjustable draft links hook to the lift arms, the bolts keep working loose and falling off. I noticed the exhaust exits about 4 inches in front of these bolts and told him the bolts may be getting hot and working loose due to vibration. This seems to have the dealer stumped too. The threads are all fine, not crossed or worn. He cuts with his finish mower and every couple hours the bolts and nuts fall off. I think he needs to route his exhaust to point down, not at the bolts. Any other suggestions or anyone else have this problem?
   / 3525 3pt hitch loose bolts #2
You could have the dealer contact Mahindra tech support to see what the bolts should be torqued to. Also, if they are sufficiently tightened maybe put on with some locktite? I don't have a 3525 so maybe someone who does will chime in to see if this is common?
   / 3525 3pt hitch loose bolts #3
you could get some aircraft bolts with drilled heads and safety wire them togather, if you know any aircraft guys they could show you how to do it. there are other ways to safety bolts to. also their are self locking nuts.
he tried loctite and locking nuts...they lasted longer but still came loose.
   / 3525 3pt hitch loose bolts #5
Does the finish mower allow for flexing when running on uneven ground? I was just wondering if for some reason that bolt was getting excessive pressure or vibrations from the implement. This shouldn't be happening anyway though. I'd defenitely check with Mahindra tech support on this.
as far as i know everything is operating as it should except for the bolts
   / 3525 3pt hitch loose bolts #7
If it's getting hot don't use a nylock nut. Find a steel locknut or castle nut or drill small hole thru the nut and bolt and use a cotter pin.
Something is definitely not right if it keeps coming loose. I would investigate it some more. You shouldn't have do this.
Good luck,
Tony
   / 3525 3pt hitch loose bolts #8
Mine did the same thing after about 30 hours. One bolt was lost. I picked up some grade 8 replacements, "torqued" them down with an impact wrench and they haven't worked loose since. I had been doing some "extreme" bush hogging, (sweet gum bushes about 2" in diameter and about 15' high and as thick as hair on a dog's back. I mentally chastised myself for not checking them as PM but those two were the only ones on the whole rig that were loose. If they come loose again I'll loctite them.
Regards to all,
Jim
   / 3525 3pt hitch loose bolts #9
I have a 3525 and haven't encountered that problem. Mine has 125 to 150 hours on it.
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
FRONTIER LR5060 LOT NUMBER 148 (A53084)
FRONTIER LR5060...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
