3520
Green Quest
can any one tell me the length of the tractor with the 300cx loader on the front i was told the tractor was 10 feet without the loader but just needed to know with the loader thanks in advance
It might be ten feet... I'll measure mine tomorrow and let you know.. but also keep in mind the 300cx has complete bucket rollover capabilities. Meaning when you completely dump the bucket all the way while it is lowered to the ground.. it is actually almost completely tucked under the loader.. which I think you would gain almost 30" in clearance.. I'll measure mine in that position too tomorrow... If you are thinking about length for putting it on a trailer, I would think the machine would be more stable in this position anyway... or if you are thinking about length for inside of a garage.. I'm sure you could park it in this position too, and gain a lot of clearance..
My 3320 w/ the 300cx is 14.3 feet from the end of the cutting edge on the bucket to the back of the IMatch hooks. Take off 5 or 6 inches to make up for the extra length of the IMatch and cutting edge.
Yeah, when we ship those tractors we usually allow for 15ft just to be on the safe side.
Welcome back, Nathan. :) Hope those quail wintered good! And that little daughter is sleeping thru the night...
Regards.
AKfish
/ 3520
thank you all yes it is for a trailer i was trying to get an idea on length
Plantations are hopping and the baby is great...hope things start to green up soon in Alaska!
Be sure to consider being able to position the tractor on the trailer properly (weight balance). I have a sixteen foot tandem axle trailer and a 3520/300CX. I only have a few inches of clearance at the front with the tractor/loader/bucket and a small implement attached. If I have the 42" forks attached, I have to position the forks out over the front of the trailer. I wouldn't reccomend anything shorter than a 16' trailer.
U probably also want to consider the trailer loaded with multiple implements as far as GVWR is concerned
You might be able to take the bucket off the the loader arms to decrease the overall length. I did this, but I have a 20 foot trailer, which gives me room to move the tractor back and forth.
I bet taking the bucket off would give you 1-2 feet on the trailer. Good luck!
