3520 vs 3720
/ 3520 vs 3720
I do live on hilly terrain and noticed the difference in my TC33D when I had rear weight on and the Curtis snow plow. My driveway is 120 feet long and at an incline. Plus I will be mowing up and down hills.
Not sure if this helps or not...
Leaning toward the 3720 but could use the extra money I save on the 3520 for a couple of implements I would like.
This is hard :)
Thanks for all the input...off to the dealer to see if he can get me a 3520 and 3720 side by side for a workout.
/ 3520 vs 3720 #12
I did the side by side with a 4120 and 4720 (both hydro) and I could not tell any difference, but then it was just a tractor and loader. Still, even getting out on the street in high range it would probably be difficult to see any difference without a load attached. See if the dealer will hook up a hay wagon or something for you.
/ 3520 vs 3720 #13
I was looking in the 3520 range myself, but was tempted by the 3720. When I really thought about it, those two models are at the high end of the 3xxx tier, but the 4120 was such an easy step upwards I ultimately went with the 4xxx series. I figured the 'de-tuned' 4120, identical in everything but HP to the 4720, would be a larger, sturdier machine than the 3xxx's I was looking at.
I guess my point is, unless you are dealing with confined spaces and you know you need a 3xxx, the 3720 should be off the table for anyone. Just go with a 4120! It's such an easy step to make.
/ 3520 vs 3720 #14
I agree. If you don't have space limitations, go with the 4120. I did and I love it.
/ 3520 vs 3720
Due to the fact that I am going to use a 6 foot finish mower on my lawn I thought the extra 800 lbs of weight of the 4000 series might cause problems.
And the wheelbase is 71" so I would probably have to go bigger on the finish mower and plow.
It is still in my mind the 3720 but I can still be convinced otherwise. I have some time to decide (a week).....
/ 3520 vs 3720
Went and looked at the 4000 series tractors and they were larger then I required or wanted physically. I think it's the 3720.
Thanks for all the help....
/ 3520 vs 3720 #17
NYBOB, I think you made the right choice. I must admit that input from this thread made me seriously reconsider the 3720 that I have on order. I'm glad that happened since I may have been second guessing myself afterwards. For my purposes, the 3720 is the right tractor for cutting large areas of relatively flat lawn with a 72" MMM plus occassional brush hog, loader, leveling and tilling work a few times each year. I think the slightly better manueverabilty, lower weight and lower sound levels were considerations. However, I can certainly see the added value the 4120 brings for just a little more money if I were not using my tractor for so much MMM lawn work.
/ 3520 vs 3720 #18
Space considerations must be considered. I have had both a large frame and mid frame machine, and can say I enjoyed both, but on my property the mid frame machine definitely is the better choice, although I did like the larger machine. Sometimes bigger is not better with regard to machinery.
John M
/ 3520 vs 3720 #19
3720, bigger in your case is more versatile.
/ 3520 vs 3720 #20
A clarification, by bigger, I am referring to the posts suggesting going to a 4120 v. a 3720.
John M
1996 Lincoln Town Car Sedan (A59231)
1996 Lincoln Town...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2024 JOHN DEERE 325G SKID STEER (A62129)
2024 JOHN DEERE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
