3520 Transmission Shift Issue
/ 3520 Transmission Shift Issue #1
Dmac1
Elizabeth, Colorado
JD 3520
Have 08 3520 eHydro. Sometimes when I'm going from A to B (stopped of course) it doesn't want to go into B. If I move the tractor a little fore/aft then it will go right in.
Do others have this same issue?
Thanks!
Dave
/ 3520 Transmission Shift Issue #2
I think this normal, drivetrain is bound up a little. Moving the tractor relieves the bind.
/ 3520 Transmission Shift Issue #3
Thanks!
Dave
My 2008 3720 does exactly the same thing. I've had several tractors including Kubota, Massey Ferguson and other Deeres which all exhibit the same behavior. I don't consider it a problem, just normal.
/ 3520 Transmission Shift Issue #4
I agree with everyone else who's posted a reply to this. My 2010 3520 w/cab displays the same behavior.
/ 3520 Transmission Shift Issue #5
100% normal. The gears are not synchronized-just straight cut and sometimes you have to move them a little to get them to mesh.
/ 3520 Transmission Shift Issue #6
Yes,..me too. My 2006,..3520-Cab has done that since brand new and even now with 1400 hours, it's still the same. I accepted it as normal long ago. Good luck with it, it's a nice little tractor.
CHEERS !
. . tug
/ 3520 Transmission Shift Issue #7
Kennyd nailed it. Non syncronized range gear box. If it won't go into gear, Just ease into the the drive while keeping a little pressure on the shifter. She'll drop right in.
/ 3520 Transmission Shift Issue #8
Interesting, 2007 model 3120 & i also noticed this from new and thought that being hydo drive it was normal. with AB & C range, i very seldom operate out of B drive. i also note that there has to be NO pressure at all on the axles to change the 4wd. slightest tension and its hard to move, just take load off axle and it slips in neatly. cheers OGh
Good to know guys. Thanks for putting my mind at ease! :thumbsup:
Dave
2020 TAKEUCHI TB230 EXCAVATOR (A64279)
2020 TAKEUCHI...
2014 Kia Sorento SUV (A61574)
2014 Kia Sorento...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
2022 EZ-GO ELITE...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
