3520 PTO Selector Lever
   / 3520 PTO Selector Lever #1
Acolar
JD 3520 eHydro, Cab
The front/mid-rear/rear PTO selector lever has always been extremely difficult to move from one position to another. Its so bad is almost bends the lever and moves the entire lever assembly to the right of the driver set.
Anyone have any ideas?
Thanks
   / 3520 PTO Selector Lever #2
This came up before some time ago. I believe it was KENNYD who posted a diagram of the mechanism along with a solution which is to loosen the bolt/nut holding the assembly together. Try a search on the topic. Might also try a shot of WD40 or equivalent.
   / 3520 PTO Selector Lever #3
There are a few pivot points...see picture below.
   / 3520 PTO Selector Lever #4
BUT.....Acolar has a Cab machine, which has a cable operated selector..I personally dont have the Mid-PTO, but from my analysis on how they install & operate, I'd check the cable itself...IMO the most likely culprit may be a kinked cable....or an impropery lubricated cable:
   / 3520 PTO Selector Lever #5
Good catch Dave, I missed the Cab part...thanks for the backup:D
Thanks Gents:
Will check the cable - we expect rain Wednesday so its a good time to do some work on the machines.
Appreciate you sharing your thoughts and manual photos.
Tony
   / 3520 PTO Selector Lever #7
Tony
Good luck Tony, keep us in the loop please...
FYI-the photo's are from the jdparts site which you can access also for free (after registering), it's a wonderful resource.
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2005 Ford E-250 Enclosed Knapheide Service Van (A55788)
2005 Ford E-250...
2023 KOMATSU WA480-8 LOADER (A52705)
2023 KOMATSU...
2014 Ford F-150 Pickup Truck (A53422)
2014 Ford F-150...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2017 FREIGHTLINER...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
