3520 - how big is 61" bucket for 300cx
   / 3520 - how big is 61" bucket for 300cx #1
tuolumne
Danby Vermont (soon)
I am considering the purchase of this tractor. I can't find how many cubic feet the 61" heavy duty bucket is. The net load capacity of the 300cx loader is 998 lbs, minus 300ish for the bucket is 700 lbs. Thats around 6 cubic feet of crushed stone. The nature of my question is two-fold. Can this tractor/loader setup handle a full bucket of materials, or does it need to be pampered? Can this loader hand loads around 800 lbs + grapple and bucket if used to move around some logs?
   / 3520 - how big is 61" bucket for 300cx #2
I have a 73" HD bucket, no problem with a full load of gravel. I always have either a weight box or an implement on the rear. I also have the rear tires loaded with rim guard. Of course with a full bucket, I keep the bucket low when moving.
At the pivot pin the 300cx is rated at: 1,198 lbs at full height, 2,125 lbs at 1.5M (59").
So what your saying is I'll have no problem with 1000 lb + logs if they're low (say 18") off the ground?
   / 3520 - how big is 61" bucket for 300cx #4
I'd be surprised if the net load capacity did not already take the bucket into account. My little Kioti CK20 loader is rated for 1070lbs so I am sure the 300cx must be more.
   / 3520 - how big is 61" bucket for 300cx #5
Never worked with logs but I think you will be ok.
BTW, an error in my lift data. Should have said: At pivot pin: 1,598 lbs at full height, 2,125 at 1.5M.
Also at bucket edge: 1,122 lbs at full height, 1,649 lbs at 1.5M.
You have to subtract weight of the bucket to get net load.
   / 3520 - how big is 61" bucket for 300cx #6
The 300 CX is rated for over 1200 lbs I thought?
   / 3520 - how big is 61" bucket for 300cx #7
I have the 61" HD bucket on the 300CX loader with my 3320. I moved 36 yards of 1 1/2" rock this past summer, with most trips having the bucket fully loaded. The loader never gave any hint of struggle and the 3320 easily moved into the pile and extracted the load. I am not sure of the weight of abucket of rock, but my guess is the 61" bucket on a 300CX will handle all you can give it. Note that at the time of moving this rock I had my 448 backhoe on the back for ballast. You will want to make sure you have enough weight on the back when moving these heavy loads.
   / 3520 - how big is 61" bucket for 300cx #8
I have a 3320 with the 300cx and a 61 inch bucket. The way I read it, the 300 CX has a nealy 1600 pound lift capacity. I have been able to easily pick up anything I can get in the bucket, that is what impressed me.
I have loaded dirt, chat rock, 2 inch rock, sand and crushed limestone. It seemed like the sand and limestone gave me the most weight up front. I have the JD weight box for ballast (with no fluid in the tires). When I was transporting a loaded bucket over some bumpy ground, the bucket load was so heavy it was lifting the back tires up a bit when hitting a bump. I slowed down and put the bucket a little lower and it did fine.
I did some checking before I bought and as far as I can see, the 3xxx series tractor with the CX loader has by far greater lift capacity than any other tractor in that class. You will not be disapointed.
On the other hand, you have to be realistic on what you try and pick up. Like I said, I can lift anything I can get into the bucket, but if your going to try and lift a 2000 pound bale, or pick up the front of a heavy gooseneck trailer or some other really heavy load, you need to get a bigger unit. You need to match your equipment for what you need to pick up. My son had used my 3320 to pick up some logs when moving trees and cutting firewood, I was surprised what he was picking up but then again I am not sure how much the trees weighed but they were about a foot in diameter and 20 to 25 feet long.
Thanks all, you've set my mind at ease. On a different note, but same tractor...I am building a small barn to store the tractor, tools etc. during my home construction project. How long is the 3520 with 300cx loader and 448 hoe attached? Also, does the hoe stick above the ROPS when considering door height? Thanks.
   / 3520 - how big is 61" bucket for 300cx #10
I have the exact same setup. I ballasted mine with a Frontier BB2065 box blade and a custom made 650 pound steel weight bolted to the box blade frame, works perfect on level ground. It's rated for 1600 pounds. After many hours of calculations and measurements, I finally figured out that the exact displacement of our particular buckets is 0.53 cubic yards.
Diesel Forklift (A51691)
Diesel Forklift...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2024 JOHN DEERE FC20M LOT NUMBER 74 (A53084)
2024 JOHN DEERE...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2011 Toyota RAV4 4x4 SUV (A51694)
2011 Toyota RAV4...
